21 - 40 of 46 Posts
· Registered
Discussion Starter · #21 ·
Belt inspection is a regular maintenance item. The belt has a service limit as mentioned above so if it gets worn to the limit then it needs changing. Belt inspections should include measuring the width which should give you an idea of your particular belt life. Belt life is more a function of how you ride and how you maintain it. If performance falls off then an inspection comes first. Age is not a criteria in my books.
Great information. Thank you!
· Registered
Discussion Starter · #22 ·
"Actually its greasing the one way in the primary that leads me to open up the CVT. "
Great info.
What type of grease do you use? Antisieze, moly lube or axle grease?
What sign that you have waited too long?
should I have replacement parts on hand when I go in?
Is this turning into too much of a thread hijack that I should start another thread?
Op let me know and I will get out of your thread okay?
If someone made a Youtube video on greasing a one way bearing, I'd watch it again and again. I don't know what/where that is or how to do that.
· Registered
"Not trying to start anything here , just telling you why I don't do it . "
No worries remember I am trying to learn here, I may not agree with you but I want your opinion/experience otherwise I would not ask.
Thank you!
Been doing it for over 25 years on motorcycles(all 4-stroke) , learned at the dealership. Never have seen a problem with injectors,sensors, rubber parts etc but it may be in the type used (aerosol fogging oil) It sounds like you are using something heavy? As well as how it is introduced. we fog through the intake with the machine running or if possible straight into the intake tract often through a sync port or vapor recovery line. It is mandatory on anything running race fuel and we always do it in the fall when the bikes will sleep for 6 months.
No need on these machines for pistons , rings etc as the nikasil and rings will be fine it is really to preserve the valve seal and prevent needing to pull heads and cut seats.I would want iron lined cylinders to be protected to prevent rust rings and sticking. I get that atv's do not get much love (based on the care of used ones I see) so performance is not often top priority but the time to fog is minutes vs a potential loss of what power it does have seems worth the risk. Hey look at it this way I am happy to be your guinea pig , fresh seats and valve faces . No injection here so I assume I will not suffer any failures with those components.
What is a IBV?
· Registered
"If someone made a Youtube video on greasing a one way bearing, I'd watch it again and again. I don't know what/where that is or how to do that. "
There are videos of people servicing the primary and I am sure it is in one of those if I come across one I will link it here.
· Regular Joe
2014 Maverick 1000r
I believe the servicing of the one-way is an older approach to the open-faced OE bearings that actually allowed for cleaning and re-greasing.
Almost every "newer" version of the one-way bearing(s) are now a double-sealed bearing, no real way to "service" them, apart from just replacing, which is simply easier to me anyway, if you're in there.
Reactions: Ducvet
· Regular Joe
2014 Maverick 1000r
Are the newer sealed bearings lasting longer?
Typically, yeah, but it's hard to even find any OE bearings in service anymore, to compare lifespan.
The main giveaway that your one-way bearing(s) are going out is shifting will become more of a chore. As they tighten up and "go out", the secondary will be driven faster and faster, leading to difficulty shifting.
Reactions: Ducvet
· Registered
If you're going to attempt the one way ,
Be extra careful when removing it from the snout . There are 2 caps with springs that engage the one way shell to the snout . Pull gently tword you and follow the twist . Once it starts to walk away from the inner sheave , wrap a shop towel around the space that's being created , and carefully remove .
They'll fly across the garage and disappear forever.
As far as greasing the bearings , all I have ever seen are the sealed ones and I just replace them if they feel rough.
Some may frown on this but when reassembling I always put a VERY light coat of Mystic red high speed bearing grease on the part of the snout where the bearing rides and on the friction washer . I emphasize VERY light.
· Registered
2021 Outlander Max 450 DPS
The parts that need servicing are the two spring loaded pawls (sleeves) that ride in the space between the ball bearings. These slide in a groove that has ramps. The first time that you do the procedure you will understand the mechanism. The ball bearings themselves if sealed don't need servicing.
The service manual is very clear on this procedure and recommends Topas grease. It was not easy to swallow the price tag of the Topas but I did not want to out-guess BRP. Others have used a substitute which they may be happy with.
· Registered
The service manual is very clear on this procedure and recommends Topaz grease. It was not easy to swallow the price tag of the Topaz but I did not want to out-guess BRP.
Topaz ?
I have never heard it called that before .
Just Googled it . I have been educated.
Topas
· Registered
Topas seemed to be too expensive to be spelled with an S but I stand corrected. Thanks. :oops:
I have 2 (two) tubes of Isoflex . I used a finger full of one of them on my one way early on in my Can Am life and the crap got slung all over my primary . I put the cap back on it and it's been there ever since .
I use Mystic red high speed bearing grease .
Maybe I'll try a bit of Echo bar & chain lube next time. It stays put on my 8k + RPM antique McCullough saw .
· Registered
Interesting I wonder how much the Isoflex is designed more for the extreme low temperature vs say a more conventional grease. It may not be a pressure rating they were after but a -50C rating for snowmobile use. Some may need / want extreme cold whatever you use for lube I would pay attention to the temperature rating.
TOZ what manual is that from I also want to say my machine did not have the plastic washer between the spring cup and bearing. Now you guys have me heading back in to the primary since I am so close. If anyone wants a picture of anything specific in there let me know, it will take a while before I get back to it but should be withing the week. NOw I will need to decide if I am ordering the plastic washer or not for my model that I do not think was there from the factory.
Well at least it was not all together yet anyway but I think this is the second time a thread has popped up about a week AFTER I did something and has changed my mind....lol
· Registered
So back to add parts to my order I looked at the 2004 outlander 400 and no plastic washer. looking all years of 400 and 450 these parts fiche show the 400/450 never used the plastic washer. It seems the 650 and up did use it so I am not sure what the purpose yet.
At the same time I noticed they do not call for Isoflex at that time buy Loctite 767 for the same location so there was a change there as well.
Here is the 767 which is a antiseize not sure if the isoflex was found to be better in wear, function or cost.
21 - 40 of 46 Posts
