1 - 3 of 3 Posts
· Registered
I have a 2020 Defender HD8 with a set of the Apache 360 LT tracks that I will be removing the tracks and putting the tires back on for spring. I paid the dealer to install the mount kit and the tracks for this season but would like to know how to do it myself. In one of the promotional videos on you tube it mentions being able to complete this task in 20 Minutes? I can't find any information on the topic or a diagram/schematic of what/if any part of the mount kit needs to be removed when putting tires back on. I know it cant be as simple as just unbolting them, can it? Would appreciate if anyone with experience with this particular track/mounting system could chime in. Thanks
Sky Snow Vehicle Automotive tire Tire
· Admin
2020 Outlander XMR 1000r Max
Unhook the torque arm bolt from the bracket that sticks down from the frame on the rear tracks. Leave the bracket assembly in the frame of the machine. Put bolt and nut back in the arm that extends from the track so you don't lose it and the spacer and washers.
For the front, remove the clamps from the front lower A-arm and remove the u-bolt from behind the ball joint. Replace all hardware on the bracket from the front tracks so they don't get lost and will remind you how it goes back together for next winter.
Pull all lug nuts and remove tracks from machine. Install tires and ride.
This is how I install and remove my tracks.
1 - 3 of 3 Posts
