1 - 9 of 9 Posts
Looking to trade my brute force 750 for an outlander 1k. I was wondering if anybody knows if my tatou 4s tracks will fit on the outlander as far as the hub goes. I know I will have to buy the different anti roll brackets. Any help will be appreciated. Thanks in advance
yes, just need the proper adapters, not sure if the kawi ones fit but i believe they both have the same bolt pattern, so you may be good to go.
Ok I meant to say it was a 2012 also. Does anybody know what the bolt pattern is on the newer outlanders?
Can-am bolt pattern is 4-137. On my Tatou tracks, the drive sprocket her multiple bolt patterns to fit different ATV's. Check to see if yours is the same.
From what I see online, the Brute force 750 has a 110mm bolt spacing. That's the same as the Kingquad. If you have the hubs with the 3 different holes for spacing, you can switch them just fine. I transferred mine from my King to my Outty.
Discussion Starter · #8 ·
Yep mine has the three different patterns so maybe a new outlander is in my future. Hahaha
my bad, i thought the bolt pattern was the same.
1 - 9 of 9 Posts
