1 - 2 of 2 Posts
throttle lever and four wheel switch" housing "coming apart
I have a 2014 650 outlander and just noticed today that the plastic body just above the thumb throttle is coming apart a little, it's two peices and the one end is starting to open up maybe enough to let water into it if it were submerged. There should be four screws holding this assembly together but there are only three, that is the way it was designed. I'm not sure it the heat from the handle bar warmers caused the plastic to warp a little bit or not. Or it could just be a poor design. If water does get in there it could cause problems , like a siezed throttle cable or electrical problems. Going to call the dealer today to see what excuses they can come up with. Take a look at your own, i'm sure i'm not the only one with defect.
1 - 2 of 2 Posts
