1 - 10 of 10 Posts
Hi i was out riding in below freezing temps the other day in some water and snow. I parked it in my unheated garage. The next time i used it the tires were frozen and i couldnt move. i checked around the axles and hubs no sign of any ice. wondering if anyone has had this happen and any ideas of how to prevent it would be great. thanks
Put heat in your garage !!! Lol
Spray it with hot water to melt it all , and get a small space heater , maybe plan a insulating party in your garage !!
Sorry I had the same issues as you until I changed my garage issues !!
Is it possible the brake rotors were frozen to the calipers? I have an unheated garage too, and was thinking of getting a forced air kerosene or propane heater, just use it to get the garage nice and hot, let it dry everything out. Not much else you can do. I did insulate the garage, hope to cut down on fuel cost.
Reactions: mikemason.nb
My thoughts too. It happens quite often to a few bikes in our hunting camp in real cold & wet conditions. Drum braked bikes are the most notorious in my experience. They lightly use a propane torch to thaw them enough to free up. If you got hydro a heat gun would work fine.
Glad I have a heated and air conditioned attached garage.
I never had a problem. Depending how big your garage is you could get away with a electric heater. Bigger garages will need a propane/kero heater. Topredo heaters work great for quick heat. Also work awesome for when you have to work outside and you need to have a little heat blowing at you. I've used one for heating up a 14x20 outside canopy in 30 degree weather. Kept it 60 degrees just fine.
I've had my tires and axles frozen before after driving in a lot of snow and parking it in my unheated barn lol I just pointed the kerosene ready heater at it and it thawed out
At a Minimum I would warm the garage when you park it, so it can thaw off and dry off before everything freezes up.
My garage stays 80 degrees because I have a wood furnace in it. Floor drains take the water out too.
1 - 10 of 10 Posts
