I just bought this identical set as a backup for my Erickson straps/chocks. This over the wheel setup works perfectly, we use it for our Maverick Sport and our X3, and I've trailered them 600 miles on a one way trip multiple times and never even had to tighten one. It doesn't budge. I used the same straps on just 2 tires on the Outlander when we brought it home 50 miles from the dealer and it didn't move at all either.
I agree, the only place to tie-down is as close to wheel center as possible. Something that does not move. And I never cross-straps either like some do. I used a chock and strap system on my first trailer and it worked well. But it limited the location of the machine too much for me. Something as simple as getting bigger tires caused me to move the chocks which meant I had to drill new holes and move the chocks. When I got a new Blizzard trailer, I went with adjustable anchor points and regular straps so I could place the machines based on weight and/or qty. I do like tire baskets/straps though. Even these simple ones in Harbor Freight would be more than enough. You could use e-track or just spread out some flush tie-downs will give you lots of adjustment.Strange that with 100 + subsections , there isn't one for transpoting your ride .
For years I hauled my Renegade in the back of my 8' regular cab 4x4 Chevy .
All that weight plus gear has taken its toll on my spring bushings ( just replaced with urethane ) .
This will be season # 3 with my Triton 2 place aluminum with plywood deck .
I have used 4 anchor points in the past but am not a big fan of hauling my bikes with the suspension squashed .
I'm kicking around the 1 strap & 1 chock per wheel system .
Wondering what all you folks are using on your open trailers .
Could be, but I never had an issue with other brands, at least not like that.The loosening seems to be all in the strap material itself . I sew my own straps to length and the polyester makeup holds much better than nylon . The tradeoff is that polyester needs to be replaced every couple years .
Four screws to remove them (what about 30 seconds), and I really don't use the trailer for anything thing else other then my Defender anyway.Big blocks in the way of loading anything else on the trailer? No thanks.
Mine would be temporary bud .Big blocks in the way of loading anything else on the trailer? No thanks.
Great that it works for you, but I'd be too worried if even one strap loosens up, the potential of the machine beating itself on the support as now it can rise slightly then go down. That's why I strap to non-moving parts, (suspension inside the wheels or the tires themselves) the machine is allowed to move on her suspension all day and never affect the straps. And I've completely lost one strap, yet the machine didn't a bit. My father was a truck driver who hauled wheeled equipment often and that's how he taught me to do it.Four screws to remove them (what about 30 seconds), and I really don't use the trailer for anything thing else other then my Defender anyway.
Before I did this with the blocks, I did have straps that were loosened up because of the movement of the suspension on the atv, and on long road trips I would often check the straps and would have to tighten them up periodically. Since using the blocks I have never had to tighten a strap that had become loose, so the slight inconvenience of having to remove the blocks if I wanted to use the trailer for hauling something else is far outweighed by the piece of mind that this procedure gives me. But to each his own.
Bingo.Great that it works for you, but I'd be too worried if even one strap loosens up, the potential of the machine beating itself on the support as now it can rise slightly then go down. That's why I strap to non-moving parts, (suspension inside the wheels or the tires themselves) the machine is allowed to move on her suspension all day and never affect the straps. And I've completely lost one strap, yet the machine didn't a bit. My father was a truck driver who hauled wheeled equipment often and that's how he taught me to do it.
Yeah everything that I have ever heard or read about what was the best way to secure a wheeled vehicle to a trailer was to secure a non-moving part (i.e. wheels, solid axle or some part not effected by the suspension).Great that it works for you, but I'd be too worried if even one strap loosens up, the potential of the machine beating itself on the support as now it can rise slightly then go down. That's why I strap to non-moving parts, (suspension inside the wheels or the tires themselves) the machine is allowed to move on her suspension all day and never affect the straps. And I've completely lost one strap, yet the machine didn't a bit. My father was a truck driver who hauled wheeled equipment often and that's how he taught me to do it.
I get what you are wanting to do, secure it like hard cargo. To me, crates and pallets are one thing, vehicles are another. I have hauled both. If you see a professional car hauler, I bet he is using axle straps. Why? Because they allow the car to move on its suspension, but not those tires.Yeah everything that I have ever heard or read about what was the best way to secure a wheeled vehicle to a trailer was to secure a non-moving part (i.e. wheels, solid axle or some part not effected by the suspension).
Remember most large loads that truck drivers deal with are secured with chain binders which movement of the suspension is unlikely to loosen one of them.
My thought process was that securing an ATV/UTV with that method utilizing ratchet straps left you with the suspension moving freely up and down putting stress on the straps and possibly loosening one or more of them. Remember when the ATV/UTV reaches the top of the suspension movement the energy of that movement is transfered to whatever is holding it to the trailer. From your own experience you said you have lost a strap using that method, my question would be "what caused that"? And the answer most probably would be the movement of the suspension.
Don't get me wrong, I truly believe that securing your ATV/UTV with this method is probably one of the best and most accepted methods that are used, I just know that I have never had a strap loosen up using the blocks under my UTV.
