okay so this is a question of interest in making some replacement parts for the Traxter.
I need a stock piston in reasonable shape along with a matching cylinder. A minimum run of 4 pistons are needed to have them made and there are cost benefits if you start looking at larger batches so this in part is to see how many are interested in a replacement piston that would then have increased availability of rings.
We could likely increase compression a bit but I am not sure that is the goal with these machines, similar with a big bore but now you are adding the added cost of a bore and plate job to the cylinder. The pistons would not be cheap but given the availability of used pistons and rings they would be much better than parting out a machine. They would be forged pistons vs stock cast pistons so there may be more noise on a cold motor but once at operating temperature they should be comparable.
There are a couple of options of manufacturers depending on budget as well as design, old designs are cheaper than a hi -tech design but again I am not sure there is much real world improvement of one over the other in a traxter.
What do you think?
Any one have some parts to measure and design off they can be returned asap. Ebay seems to still have no options and if I can not come up with any I might tear mine down again to measure but that will not be until work slows down again.
What do you think?
