What are the symptoms of a bad u joint, how it feels while driving...
Which brand did you buy from canamparts guy? Spicer, Neapco, or the OEM ones? and why? Thanks.I just picked up some high quality u joints from canamparts guy. Gotta get my drive shaft out and swap them.
These:u joints high qualityWhich brand did you buy from canamparts guy? Spicer, Neapco, or the OEM ones? and why? Thanks.
Thank you for the prompt response. Since these fit on your 2017 XT, they should fit fine on my 2016. Can you please confirm? And how many miles have you had on them so far?These:u joints high quality
I opted for these per Jared from can am parts guy. The zerks are on the outside vs being between the yolks. These make greasing easier!
I would imagine so yes, it shows it fits all v twins. I have put 500 miles on roughly since I redid them. WAY easier to grease/service. Id also suggest replacing your wear ring since you''ll have the drive shaft out. I used a cut off wheel to cut if off. Then a press to press it back on. Make sure you put it back on the RIGHT way.Thank you for the prompt response. Since these fit on your 2017 XT, they should fit fine on my 2016. Can you please confirm? And how many miles have you had on them so far?
I'm debating between aftermarket and OEM and from what I've read, OEM seems best but I also know that Jared only sells quality stuff.
Any insight would be highly appreciated.
Well noted. So although the description says rear u-joint, I believe that covers both u-joint a between the gearbox and the rear diff since the parts diagram shows the same part number.I would imagine so yes, it shows it fits all v twins. I have put 500 miles on roughly since I redid them. WAY easier to grease/service. Id also suggest replacing your wear ring since you''ll have the drive shaft out. I used a cut off wheel to cut if off. Then a press to press it back on. Make sure you put it back on the RIGHT way.
Jared knows his stuff, he's local to me and fantastic to deal with.
I need my rear shocks rebuilt, they are leaking oil terribly bad...![]()
I've done this job before with the front diff so I'm familiar with it. When I did it, I replaced both the wear ring and the oil seal. Shall I also change the oil seal for the rear diff when I perform this job?I'd also suggest replacing your wear ring since you'll have the drive shaft out. I used a cut off wheel to cut if off. Then a press to press it back on. Make sure you put it back on the RIGHT way.
I've had my rear prop shaft off 2x times now and haven't replaced my rear main seal yet. 1 time to replace rear diff with mud n wheels, second time due to finding one bad u joint. I am going to probably kick myself for not doing it. We'll see.I've done this job before with the front diff so I'm familiar with it. When I did it, I replaced both the wear ring and the oil seal. Shall I also change the oil seal for the rear diff when I perform this job?
Yes. Factory u-joints. I bought the machine used from a mechanic who is the original owner so I'm sure he was always on top of maintenance and always greased them. The quad never went through any deep mud mind you.The u joint I sent will be the same u joint for both joints on the rear prop shaft/drive shaft.
6k miles and factory u joints? That's awesome! Have you checked them for play at all? Do you still have the stock rear diff also?
Thanks a lot for all your input. It is much appreciated. I wish more users on the forum were using these made in japan high quality u-joints so that we know how they compare to OEM ones. I really don't mind greasing the OEM ones since I have a smaller grease adapter that fits very easily with the zerk. I'll probably make up my mind today.Well, ease of maintenance here is a win for me... Truth be told, I didn't know the front joint had a zerk. Which is why it failed. I ride water and mud alot. Anyway, now that front one gets grease just as much as the back one, and the rest of the zerks. I try to grease after every ride.
Same here. I try to help and share as much as my time allows.No problem! This place should be used as a tool for people who have questions. I love forums.
