1 - 8 of 8 Posts
Hey I've got a 2013 renegade 1000 NOT XXC
And I've had a bit of trouble once in a while when I go to
Winch people out and when there ou we usually have a
Beer and I make the mistake of shutting it off
So it won't start because it's too dead I'm just looking
For options for "better" batteries the the stock one
Without putting two in it and would rather not have to mod
It just for a battery lol thanks!
Me too. I have a 07 800 Gade and been looking for an upgrade version without going to a lithium style for 256$. I thinking the Odyssey pc545 or the pc680-p
Sent from my M865 using Tapatalk 2
Look at the spec on the bat.
The 680 bigger of the two has 185 cca
A stock bat has 310 cca
That should be a no brainer
Now the Lithium has 420 and THEY CLAME that is can be recharged to 90% in 6 minites.
Not all that convinced the lithiums are a up grade. They seem to be breaking plates. They have replace the battery at no charge. Iv read quite a few others have had the same problem. The other thing with them is you cant put more than a 2 amp charger on them
It says 535 cca for thirty seconds and can't remember of top my head but thing 375 cca for minute. The other series battery I listed Ostacruiser posted that it was the one he was using. Couldn't figure it out cause the cca was so small
Okay I just looked it over again and the PC 545 its actually only 150 cold cranking amps the hot cranking amps is around 545 for 5 secs 495 for 10secs and 420 for 20 sec. So why the hell is that the replacement that it says I need. I hate searching for batteries so someone could just give me a part number that they used that would be awesome. Cause right now it says that this is the battery I need for the replacement but I know its not because of their specs
You listed 2 Odyssay bats. 545 and 680. The 680 has the higher spec but it is no where near that of a stock bat. Which is 310. Look at the CCA not the amps for x seconds (420 for 20 seconds). Do you think you will only be winching for 20 seconds. Like I said earlyer the 680 has the higher of the 2 bats and the stock is 310.
Ok. So just get a battery from Napa I gonna have them cross reference my stock bat. Unless u no one that is good for a decent price.
1 - 8 of 8 Posts
