Any one else have problems with driving their Outlander v-twin in winter? Specifically watery oil.
I live in Alaska and it gets pretty cold.
Both me and a friend have had problems with water in the oil during winter.
Mine: drove it most of the winter and engine light came on saying low oil, but pulled the dip stick and watery oil came gushing out. Coolant was low, so I figured my water pump seal went, so I changed it, and a few days later happened again.
Friend: Had watery oil, so he changed it. Few weeks later same watery oil and it sounds like his crank bearings went out----probably caused by water pump seal going out? Just checked his oil and it was watery again.
I parked mine for the winter, and we are going to start tearing his apart next week.
It just seems like the water pump seal is our culprit. Seems like a bad design having the water pump seal on the other side of oil. I'm thinking the seal is freezing stiff and allowing coolant to flow into the oil from the pressure.
I don't think I did damage to mine, but his definitely doesn't sound right. (pretty bad knocking)
I would like to think that we can drive our machines year-round, but it just seems to be a design flaw that's causing this?
This ain't a vent, and I'm not trying to knock my can-am (I have 4 of them and plan on getting another)...just wanted to see if any one else had problems driving their can-am in the winter. I usually just drive my snowmobile in the winter, but bad snow conditions cause me to use 4-wheelers.
This is the same engine that's in the Ski-Doo V-800, and you would think that they would have engineered for extreme cold.
Any thoughts?
Any thoughts?
