This past weekend a group of us were riding the state trails in northern Michigan. With the little rain we had, it was a few days of very dusty riding. On the last day, my buddys 2020 Outlander Max XT 850 stalled. No limp mode or other messages on the dash. We cleaned the filters and continued our ride however the machine smelled of gas and had little power. It was also burning through a lot of gas. Upon arriving home he was in the process of cleaning filters, changing plugs, etc. Since the side panels were off he decided to check the valve clearance. The machine is not ridden hard and has less than 200 miles. The first pic is the plugs he removed. The second pic is the valves at the rear of the machine (number 2 cylinder).
Here's the info he sent me...
Starting with the number 1 cylinder I rotated the engine clockwise until the two marks on the gear were parallel to the head and it showed a 1 through the sensor hole. Intake valves were a bit tight so I adjusted them to .004 I took the valve cover off the number 2 cylinder and rotated the engine clockwise until the lines on that cylinder were parallel to the head and a number 2 was in the sensor hole. I made no adjustments to the valves after seeing there was approximately a 1/4" valve clearance on the intake valves.
Any ideas on what is going on with the number 2 cylinder intake valves?
