Got some more Can Am goodies for the ATV's and the SxS's
VFJ fully adjustable weights and spring kit.:aniwheeler6:
These weights have massive adjustability from 34.5 to 46 gram covering 650-800-1000cc's in the Renegade, Outlander and even the Commander 1000.
Above you can see These adjustable weights can be bolted from either side. With these weights you can add and subtract mass from Mid and Tip areas of the flyweight. These use ultra high quality screw in fasteners both steel and billet aluminum, screw in, screw out. There is nothing to drill out and replace or purchace again if you want to really test and tune until you are satisfied.
The Base Curve at the beginning of the ramp will lessen higher rate stall engagments but still give you that low and mid punch these clutches need vs the stock weights.
This pic shows them with the fasteners that are included and will cover most all increments inbetween 34.5 to 46 grams, they are adjusted with the included bolts and washers of various weights and sizes included in the kit
Here's what you get:
3x Adjustable arms base weight 34.5 grams
12x Aluminum bolt head fasteners 0.8 grams each
12x Steel fasteners bolt head 2.15 grams each
12x Thin steel washers 0.5 grams each
6x Thicker steel washers 1.5 grams each
3x Tungsten washers 3.5 grams each
I have some primary springs ready but will be doing some testing before I finalize rates. I have been running my VFJ#5 kawy spring for months and I have made a thinner diameter can am replacment 60/160 which seems to do very well in the 800 as well as the 1000. I have optional larger rate secondaries for bigger tires as well. I am working on the 1000 torsion spring secondary spring as well, but I feel it may not be needed unless you run very large tires or pull heavy loads.
I'm still doing some testing (dyno and asphalt drag strip 1/4 mile) before everything is finalized this weekend while my motor is still stock.
The weights and all adjusters will be 200.00 :yahoo:
springs are 25.00 each :th_smiliethumbsup:
John
