1 - 2 of 2 Posts
Is there a good video out there on installing a winch (in this case Viper 4000lb) in a 2019 Defender HD8 with DPS? I'm reasonably mechanical with R&R type of installs.
Discussion Starter #2
Installed the winch on Saturday. Took me a little longer than I expected as I had trouble attaching the winch to the winch plate. Tip...us a small flat head screwdriver to lift the recessed nut on the winch to make contact with the bolt. After that pretty straight forward removed the passenger side flooring to run cables. Installed the contactor near the battery. Cut out the switch template using my Dremel and wired it to the ACC post. Attached the cables and ran a quick test. Re-installed the floor and it works perfectly.
1 - 2 of 2 Posts
