161 - 180 of 187 Posts
Took my plow plate to work today and plated it in high phos nickel. So now it looks cool and it won't rust during the winter. Now I'm thinking what else would be worth taking off and plating. Have access to black oxide, Copper, Silver, cadmium, nickel in high and mid phos, hard and soft.
Sent from my Pixel 5 using Tapatalk
2018 can-am outlander XT 650 (abs) with mod's
Wired new rear power outlet for wood trailer crane. Let's see if 25mm2 and 150amps forklift connector keep up..
Reactions: czerp1982
2020 Can-Am Renegade 570
Not even a year.. and one of my heated grips (OEM can am) has some play where I can slightly twist it back and forth. Anyone else have this issue?
The little bolt is tight..
Mine have that and I just put them on this last winter, I think they are like that when you got them but you just didn’t notice until now.
2017 Can-Am Outlander 570 Pro
Literally nothing, went riding in this beautiful weather. 🤣
Plant Speedometer Light Vehicle Gauge
Fix my gear shifter = Last weekend it broke when i was do some wood "collecting"..
"little load" as always:
Wheel Tire Sky Cloud Vehicle
Today load was "little" too:
Wheel Tire Plant Vehicle Automotive tire
And now you can spot different from these pictures:
What did not last previous trip also :whistle: ..
Got some funny looks from bystanders = When i drove through city.
Discussion Starter · #172 ·
The wood on the trailer? Looks heavily loaded.
Noticed my rear left side seems to sit lower than the right side. Tire pressure and preloads are the same.
What’s the next spot to check? As I don’t see any obvious broken/bent parts.
The left side sits a tad more than 1/4” lower..
Vertical frame of crane is bend back = Lower weld broke... Every load is test load
2016 Outlander Max XT 650
Which part in specific broke and how did you fix?
I absolutely love your setup mate, the combo is above good. 👍🏼
Reactions: Jack796
Regular Joe
2014 Maverick 1000r
@Jack796 those pictures are torturing my eyeballs, lol, too small.
Reactions: EbenezerScrooge
2021 Outlander 850 max XT-P
I've heard that because that side is so close to the exhaust that spring fatigue happens due to heat. Not sure how true it is but I guess it's plausible. If you don't find anything else then maybe it's true.
Who knows
50 hours heavy use maintenance. (aka light 100h)
612hours and 14214km..
Reactions: BombardierBomb
