1 - 20 of 25 Posts
Is anyone else commonly shearing off wheel studs?
I've gone through several now. All torqued to spec. with stock wheels and tires.
can am 1000 XTP Max.
Cheap garbage quality can am wheel studs being used? or am I the only one?
I've ran a lot of performance quads.. never had this issue.
I haven’t broke any studs but apparently I stripped 2 holes in the wheel hub and I followed torque spec. What a joke. I’m only torqueing to 60 from
Now on
My 2013 650 torque spec is 74 ft/lb..what does your manual say?
The only other thing is when putting the wheel on if its getting jammed crooked & your running the nuts on stretching the studs or using a impact unevenly then torqueing to see if its in spec. I see so many techs using impacts improperly on wheels all the time, you need to run the nuts on slow as to center the wheel first then tighten a little as you go, also put antiseize on the threads for equal distribution of torque on the studs.
Discussion Starter #9
Last time was 3 wheel studs.
This time 4.
50hrs.
Plus apparently valve and diff seal need replacing and so do the rear brake pads.
Lol. jesus..
Can am's... great machines but they are the KTM of atv's for parts eh...
I broke one of my rear studs today.
I didn’t get past 65lbs and it soften up then snap!
Reactions: Brandon Lindgren
I have never actually torqued my wheel nuts I always used my electric snap on 3/8 impact. Had wheels off at least 100 times with just a very little dab of copper anti seize.
1 - 20 of 25 Posts
