61 - 68 of 68 Posts
Boy thats intelligence at it's best. Thank god for the internet to give people a place to function. Thanks for your suggestion though.
Man this forum sounds like a bunch of paid spoke people for BRP, Why would anyone buy one of these ATVs knowing they have these sort of problem's and just figure I will band ad it? man I feel stupid for not reading more before I bought but to buy one knowing? I don't feel so stupid after all. There will be a new crop of buyers everyday so if my wining helps one person then it is worth it.No one here would accept buying a new car or truck that had these problems and not scream bloody murder to the dealer so why accept this crap from a offroad Mfg? makes no sense. I don't care how old the problem is IT DOSE NOT MATTER IT'S NOT RIGHT.
I just bought my first can am (outlander xmr 1000) I did tons of research and question asking before deciding. There are more Polaris washing machines in the junk yard than cars hints why you got rid of your last 3 Polaris and went w can am now you know why I didn’t go w Polaris as well. I haven’t even picked mine up from the dealer yet (pick it up next sat aug 1) bought it 5 hrs away 2 reasons my dealer is garbage and don’t care unless ur in there kissing ass every week paying them $$$ learned that w my 2 seadoo, 2 no dealers closer other than mine and 1 other (2k more) had them In stock. But back to the discussion of research and buying one I bought this fully knowing heating issues I have already ordered header wrap and picked up a piece of aluminum from work last week anticipating the arrival of my machine less than $50 you can be much happier for another $350 you can buy a new ecu already flashed like I did bc I didn’t want to wait to ride and also didn’t want to wait while sending one away when I change tires ect... research any major purchase you make don’t blame the seller... like you said it is their fault to a point as well as the strict emissions but we want that power so they do what they can to get us a decent product w easy fixes they can’t tell you to do it bc that will break the emissions laws it’s a fine line...
48hp 4 more hp than your beloved Polaris... Tune it back to 44 and your heat issue will be solved permanently..
Don't waste your money, the coatings are only making pin pricks at the problem.
I ceramic coated pipes for my Harley a while back. They did the inside and outside. It may have helped with the radiant heat but it was nothing much as far as I could tell. My main reason for doing it was they were an old set of pipes the chrome had gone bad on. The ceramic coating has a dull silver finish which looked good on the bike and the place that did it was local.
I wouldn't invest in it for performance or heat control on the quad.
I did the piece of angle under the heat shield. Not much different from the others. I bent up a piece of 10 gauge aluminum about 2" tall and 1-1/2" deep. I did remove the heat shield so I could bolt it on. Not a big deal to pull it off.
I had some of the Thermal Tec Cool It acoustic and heat control blanket left from the old Commander. I applied it to all plastic panels.
I'm in central AZ and we are firecracker hot now. Took it for a test ride, probably 98' outside. A substantial difference. My left leg was fine and I was wearing shorts. So I am guessing the combination of the aluminum angle and the heat wrap worked.
I think I will hold off on the re flash for now. I may consider the Dynojet power commander fuel and ignition module. I've used their stuff for years and never had any issues. If I can cool it down a little by giving it some more fuel and adjusting the timing that's all I am looking for. This thing has all the power I need.
99111
99112
61 - 68 of 68 Posts
