Will 33s clear on 23 lonestar
656 Views 10 Replies 4 Participants Last post by  P.T
Been looking at some YouTube videos, a lot of people putting 33 boggers on there machine with 20in fuels, good looking package, most are useing forward offset superatv arms, the new lonestar I have came factory with 30s and arched forward a arms, was wondering if they would just change out and would machine handle them alright,
This is just a idea, so let me know what you think
1 - 11 of 11 Posts
You can probably get away with it with our 2" forward arms. We rate them for a 32" max, but we're stupid conservative on that....so that's the absolute most extreme compression and turn possible...on a true 32". You're 33"s will likely measure short....and you're never going to get into that crazy extreme suspension situation, so you should be totally fine with 33"s and the 2" forward arms.
  • Helpful
Reactions: 1
This machine came factory with foward and arched a arms, just don’t know exactly how much forward
Reactions: 1
The previous Defenders to model year 2023 had 27 inch tires. For 2023 when they put 30’s and forward A-arms in some of the machines, I would bet they are 2” forward arms.
You dealer could confirm but that is my guess in looking at my 2023 Limited Max.
2
Here’s some pictures, got almost 3 inches in clearance at turn
And you've got all the adjustment in the lower perch still, too
Didn’t see no adjustment
See the steps in that lower spring perch? If you turn it, it'll give you a little bit of added lift. Shortens the spring, basically, raising the machine.
Reactions: 1
I gotcha, I thought you was talking about adjustment in a arm👍
Reactions: 1
1 - 11 of 11 Posts
