1 - 10 of 10 Posts
I bought the “worlds most badass belt” for $170 and I just installed, it is def beefier than oem belt but it sticks over secondary clutch about quarter of an inch unlike the oem, description says fits all 450 models 2007-up so figured I was good, but I put the cover on and gave a test roll and almost immediately going slow I had plastic shaving blowing at me through my cvt exhaust snorkel, I read someone else say they did that and it was good after a minute because it wore a small divot for the belt and never would eat through the plastic cover . My question is should I do this or what is my option?
What belt number did you install and where did you order from? I see some sites say the vtwins and 450 use same belt number and that is not correct.
2021 Outlander 850 max XT-P
I have seen them list the same belt also. SuperATV is one of them.
I'm sure if you want to order the other belt someone will buy that one from you.
Yah that wbb302 is not correct.
I ordered from superatv so I guess that’s where I screwed up
I usually have good luck with superatv. Juat contact them they will get it handled.
Reactions: Tozguy
Discussion Starter · #9 ·
1 - 10 of 10 Posts
