XMR Power Issues
1735 Views 13 Replies 7 Participants Last post by  Digitalxmr73
So i turned the key on my bike off after riding it. Everything powers down like it's suppose to. I walk back in my garage and the xmr is powered back on with the display just sitting there blank. Any ideas?
1 - 14 of 14 Posts
650 800 1000? my lights on the 100 stay on for a while after but not sure about the display
its the 1000. My lights stay on for awhile too but what i'm saying is i wait until they turn completely off and then if about a min or so the bike randomly turns itself back on.
Hey I had the same problem. Its water going inside key switch and it rust and shorts. Take the ignition switch appart and clean, die elec grease, reseal wth silicone and ur good to go
What Wellerd said is what i was thinking. Turning the kill switch off will turn the power off but still be good to fix the key switch.
I would think you have some green plague going on in the switch and bleeding voltage over or in a relay somewhere
unplug the switch and see if it still happens
Yes this same thing happen to me the dash is bright but not displaying anything but it has been doing this from day one
Key switches in the gen2 bikes for some reason get water in them. I've seen it alot.
Ur saying right where I stick my key in, water is getting in that hole and making my dash light up?
yes. take ur ignition apart and clean it . grease then seal
Um ok sweet but will I know where to apply both the dielectric and the silicone separately
yes die elec goes where the conection is and you will see its probly gona be green n rusty where it should be chrome or coper. and the silicone is where the 2 peaces come together
im trying to atach a pic of how mine was
cant upload says erro if u wanna see send me ur email and then u can try n post it in here so peeps can see what it does inside
1 - 14 of 14 Posts
