2005 Bombardier Traxter XL Clutch and/shift problems
9.8K views 5 replies 3 participants last post by  JohnOwens
#1 · (Edited)
Update: all 5 speed numbers flash after I press the shift up or shift down toggle switch. They stay on until I kill the engine.
I just purchased a used 2005 Traxter and it worked for 2 days. While driving it in 3rd gear it popped into Neutral, at least that is what the indicator light showed. So I pulled the lever back into High Drive, but it wouldn't move. I put the Traxter up on blocks to let the wheels move freely. When I shift the lever between Park, Reverse, Neutral, High, and Low, the engine makes a sound like the gears have engaged and I see the wheels spin a few degrees, but then nothing more. I checked and the linkage from the Park, Rev, Neu, Drive shifter is physically moving the shaft entering the transmission.
Can this be a clutch or shifter solenoid issue? If so, how can I check it?
Thanks in advance,
