I am entering my 2007 800 XT in an atv pull this weekend. Does any one have any pointers since this is my first atv pull? I have 26" GBC dirt tamer tires on it.
Thanks.
Thanks.
CC1999: Prefvious reply was right on the head. ACT are the lowest profile of the tires listed. They have soft rubber and aggressive lugs. Bighorns are harder rubber and the rubber to void ratio is worse.
At my first OL800 pull (ran a Traxter before and was never beaten, by any class) I'm debating running more air in the front tires to reduce resistance. Even in 4WD they probably do only 20% of pulling because of weight transfer to the rear.
You can only add weight to the front to the max weight for the class you're runnung, usually about 1200 lbs w/rider for the largest engine size. They'll have sand bags you can use. You will be weighed. Usually you can also run in UNLIMITED when you can add as much weight as your front rack can carry. Off the line don't gradually give it throttle, peg it full immediately. Good luck
Did you mention reversing the FRONT tires. That would be a waste of time. 80% of your traction will come from the rear. Personally I think the paddle tires would be worthless. Too many smooth areas with no tread. Both frt and rear have to be the same diameter you know. Unless you ran 2WD.Ok tchobbs, Turbo lost me a little, my falt though. I did't like the tires or the wheels that came on my XT, so they came off pretty much after one 30 minute ride on them I never looked to see what kind the were. I still have them though. My main concern with using those tires is that they are heavy, There were some sled pluller guys on Kawiriders that told me to watch my rotating mass, As I recall those ACTs are well over 30 some odd pounds each. Those zippers are under 20 each and so are the dirt hooks I was thinking of running backwards on the front. Whats your thoughts on the rotating mass.
Ditto. I've never seen anyone gain even 6" jumping around on the bike or twisting the handlebars back and forth.Momentum is key...wick it and keep it wicked...it's got a rev limiter.
Please don't bounce up and down...you'll look like an idiot. If you're slowing down that much, you're done anyway.
Wider isn't better. Setting your reartires out will make it want to "steer" you unevenly as each tire hits different track. Like if one tire hits a loose hole and the other gets good traction, you will turn. Having a wider offset on the rear axle makes it worse. If you want to have your fronts and rears bothdriving on new track, (not following one another)offset the fronts out and offset the rears in.I have noted on some of the pro pulling setups they run those tires out real wide, would those make a good combo.
