Which one are you guys buying, Cvtech or Cvtech HD?
And are you eliminating the one way bearing?
Sent from my SM-N950U using Tapatalk
Engine Braking is the most annoying feature on my Quad. When I replaced my primary it had no one way bearing engine braking was still there just not as much & freewheeled 7MPH & lower when I replace my secondary, STM has a option for the helix for even less engine braking its so much more enjoyable to ride.I'm well aware I'm just not sure why you wouldn't want engine braking?I have a 2016 renegade 1000xxcIf you have a Rotax 800cc and above you need to purchase the CVTech with the Billet cover plate. Also I am unsure of why someone would want to eliminate the one way bearing?
I can't seem to update my profile.
One way bearing eliminates engine braking
I have a 2016 renegade 1000xxcIf you have a Rotax 800cc and above you need to purchase the CVTech with the Billet cover plate. Also I am unsure of why someone would want to eliminate the one way bearing?Which one are you guys buying, Cvtech or Cvtech HD?
I'm well aware I'm just not sure why you wouldn't want engine braking?I have a 2016 renegade 1000xxcIf you have a Rotax 800cc and above you need to purchase the CVTech with the Billet cover plate. Also I am unsure of why someone would want to eliminate the one way bearing?Which one are you guys buying, Cvtech or Cvtech HD?
