If the ride is stiffer and harsher than stock, they are not set up correctly. Dont let that statement influence your decision.
Well, that's not totally true.
If you want plush shocks you can have them, they won't ride as well at higher speeds.
If you want shocks that race better at higher speeds, they will be stiffer than softer shocks...
Overall with the sag properly adjusted and even with the compression at 1, my elkas ride stiffer than my "stock xt setup" which felt like bouncing on springs. It was more "plush" because it felt like bouncing but the handling was horrible.
2 things are nice with elka shocks:
1- they are custom made for your needs so they will be whatever you ask for... i asked for "agressive trail riding". I didn't ask for "plush shocks". It doesn't mean that they are not set up correctly.
2- you can adjust the compression clickers to get them closer to where you want, you will have approx 10 clicks each way, they set it "about right" in the middle, so you can have them stiffer or softer, but it will affect your handling.
You can have elka make the plushest shocks for you, they just won't race as well, but maybe you don't care about high speed handling and that's ok, that's why they make custom shocks, but you can't have it all on the same set.
You get used to it though. When I got mine, I though elka got them wrong because they were wayyy too stiff, so I set them at 1.
They were more "soft" and ok riding, but I decided to try it stiffer. The handling was way better. So I increased 3 clicks until I got it to like 16 clicks, and the ride gets pretty harsh but it's laser handling. Down to 12-15 or so they ride really well and steer well.
So you know what, elka got them just right for what I asked for, aggressive trail riding.
Seriously I can drive almost twice as fast as before and it just steers straight ahead, it's like bumps don't matter anymore and before it would just throw me left and right and make it unsecure and I had to slow down.
