Grinds when shifting into high
6.2K views 32 replies 5 participants last post by  CanAmRancher1
Hello all, well I have a problem.
My 2017 Can Am Commander 800 won't shift when running.
I can go through the gearset when it's off.
If I start it in neutral and shift into high, big grinding noise.
Clutch, blown gear box$$$ whatcha think
Discussion starter · #5 ·
Don't try and shift into high from neutral when it is acting like this or you will end up needing a gearbox.
Other than that just blow everything out and have a new belt on hand as it may need one depending on mileage.
Uatv tech has a good bearing set that isn't chinese and not as expensive as oe.
Thx. Finally got the parts, gonna try this weekend, hopefully that's all it is.
Discussion starter · #6 ·
So I got the parts but clutch is stuck. Can't get it out. Any help is greatly appreciated. Thx
Discussion starter · #19 ·
Cover is off.
Secondary spins when throttled. Helix appears to be lined up.
Removed and reinstalled the shaft,
[QUOTE="CanAmRancher1, post: 1298849,
Discussion starter · #23 ·
Went for a ride pulled into garage, couldn't get it into park. Replaced 1 way bearings. Checked both primary and secondary clutch, all good, re installed, now just reverse, creeps, can't get into and other gear
