Renegade won't start
1 reading
16K views 6 replies 6 participants last post by  mudjunkie
Hi, my renegade will not start. When i turn the key on and hit the start button, I hear one click coming from near the gas tank. This is what i have done to try to fix the problem. Bought a new battery, checked all the fuses, checked the starter, checked most of the grounds. When i take a jumper cable directly from the battery to the starter, the machine will start. I am not sure i have found all the grounds, and i have yet to get the relays checked out.
Any ideas?
Thanks a bunch
#3 · (Edited)
Starter Relay (solenoid) probably? Diodes blown or installed backwards? Do you have it in Park and pressing on the foot brake?
Do you have a service manual? I'm looking through one for you now.
EDIT: Here is Troubleshooting from my manual. - But it truely sounds like it's your Starter Solenoid, if you hear it click but not spin the starter. Temp fix would be to just carry a way to short out the solenoid for now so you can still ride it. I use the head of large channel locks.
wont start
mine is also turning over but wont start. would it still turn over if the key went bad? Or would it still turn over if the kill switch went bad. I would think either case would not allow the motor to turn over, any ideas. This started happening when i was in water up to my foot pegs.
