2014 commander , 4x4 wont work
4.8K views 9 replies 2 participants last post by  BombardierBomb
So the machine has 97 hours and 550, it has 4x4 but the light on the dash doesn't come on anymore. It's not the fuse, ik you may think it's the fuse but the winch works and toggle switch lights up. When I hit the switch to put it in 4x4 nothing happens, I don't even hear it trying to engage. Pleas help!
Welcome to the site
The switch starts all the fun. Those switches just go out from time to time. Yours probably isn't throwing a good connection to power the actuator.
Yes, the 4wd light is illuminated by a little plunger switch in the actuator housing. When the actuator slides the lock collar, it pushes the little dip switch in there, and the light on the cluster pops on. If the switch isn't starting that dance, you won't get the light
So I've installed the new rocker switch and still nothing, any suggestions on what to do now? I have service scheduled for it as I just purchased the machine but that's two month is from now. And was wanting to use it before then, thanks
So something's amiss with the actuator and/or harness/connection. There's a test procedure in the shop manual for it. Have you downloaded your free service manual from here on the site?
