41 - 45 of 45 Posts
2018 Can Am Defender HD 10 Lonestar Max... Keeps going into LIMP HOME MODE and throws the OP 1613 and IP 1615 fault codes. First of all what is with the "O" and the "I" and has anyone else seen this. My dealer in Victoria, TX couldn't duplicate the problem after $500.
P1F00 code popped up and sterring just locked up . Does anyone one know why that happened I'm lost . And A ( ! ) symbol popped up too
Your DPS probably failed here´s something i found regarding another Can-Am
"Dps failed going around a turn causing the operator to go into the opposing lane of traffic. P1f00 code first code P1F05 only happened in drive way, dealer could not duplicate. dps went out in a turn and code P1F00 even though the dealer had both codes in memory yet brp would not repair without duplication of errors.
I have a 2021 570 Outlander that was showing intermittant charge at high speeds but not during idle. The check engine light also came on and then fuel sensor fault. The amp display also was showing fluctuations from 12-15. The negative battery post connection was loose and all seems to be well
41 - 45 of 45 Posts
